What are my options to drop my vert?
  • Kwaaahhh
    • Apr 2008
    • 843
    I was wondering if you guys can help me out on this. So I got my vert. for about a month now and just finally finish up the exterior. I'm not trying to autox or track this car anytime soon or never. Its basically my DD. With my pass few cars I always have run coilovers on them. So I'm hoping to do the same with this vert, simply so i can adjust the height to my likings. I'm a total noob to this car, so I don't know anything about suspension for her.
    So my question is the car currently have some bilstiens on it, not sure what model. (Will check tomorrow) I want something like this:
    What do I need to do or modify to have those work on my vert. with the bilstiens? Is it even possible? Also what spring rate would I need to get? I'm basically trying to get the stance and drop. Please help a brother out! TIA!:D
  • Kwaaahhh
    • Apr 2008
    • 843
    Anyone?
    • haso
      • Jun 2008
      • 37
      cut the springs
      • Kwaaahhh
        • Apr 2008
        • 843
        Other than the previous idiot answer, anyone?
        • 318isbmw
          • Nov 2005
          • 2843
          Those should work on your e30. Since you select the ratio and all you should be able to set it up to accommodate it being a vert and having all of the top setup weighting it down. Suspension is the same.
          ninja edit: I was referring to the gc coilovers. And the Bilsteins will work with them as you can select that your running bilsteins on gc's website
          • Kwaaahhh
            • Apr 2008
            • 843
            Thanks man! Any suggestion on the right spring rate to go with for f/r? Also the spring height? Thanks!
            • platanos
              • Apr 2008
              • 459
              There is a group buy that will save you some money going on right now on these GC coilover kits....check it out
              here is the link http://www.r3vlimited.com/board/showthread.php?t=112810
              ~Fernando
              • Kwaaahhh
                • Apr 2008
                • 843
                LOL! Thanks man I'm on the list already. Just trying to gather up info on the correct spring rate and height!
                • 318isbmw
                  • Nov 2005
                  • 2843
                  Not sure at all, sorry, but Jean said he should be able to help.
                  • Kwaaahhh
                    • Apr 2008
                    • 843
                    Anyone got some advice or suggestion for spring rate and height?
