I’ve just finished plumbing in an old 735 H31 hydraulic brake booster system into my e30 (for the reason as to why on earth I would do this see my “ITB’s are GO” thread in the M20 engine section). I have a few quick questions about hydraulic fluid.
The reservoir for the H31 system warns only to use “Pentosin” hydraulic fluid, but I believe this is for reason of the self levelling strut system in the old 7 series my H31 system came out of. So, my questions are as follows:
1. Does anyone know if I can run the same ATF I would normally run through the PS system in the H31 booster?
2. If I have to use Pentosin can anyone tell me if this product is compatible with ATF (am I going to have any weird reactions between the Pen and trace ATF remaining in the system after I drain it)?
3. If Pentosin and ATF no mix’ie mix’ie, how do I best flush the system?
