The conversion went well. No surprises, filled up the system with ATF, test drove it.. perfect... After half hour of driving, the power assist was gone.. I had to work on the steering wheel to be able to turn.
Sometimes I get power assist when I rev up the engine, but most times I do not. The car has < 100k miles, and the old fluid didn't have any metal shavings in it. The old rack is good, with no leaks, but it did require more effort than any other car i've had.
a) pump failed
b) the new steering rack is bad (maval rebuilt from bmaparts)
c) shitty ATF from ACE hardware
d) I may have run the hi-pressure line too close to a heat source, and fluid is overheating
Any other ideas?
a) pump failed
Any other ideas?
