Spring Pads
  • stormspike
    • 401
    Spring Pads
    What is the part number for the rear spring pad? Also, how hard are they to install? I need to raise the rear 1/2 inch or so. Currently on IE 3 springs with Koni's. The rear needs a little lift (damn sub in trunk) before I get the new rims on. Any install help or part number would be great!
  • ddavidv
    • 344
    p/n 33531136385, listed as 5mm thick
    If you unbolt the shock at the bottom and maybe the sway bar the control arm may swing low enough for you to put them in, especially with lowering springs.
