Cutting my springs.......
  • E30-ICEMAN-E30
    • Jun 2008
    • 3
    Ok so I need some help.... I really want to lower my car. So what I was thinking was that I could cut a small portion out of the springs to make it lower. Has anyone done this??? Does it affect the ride quality or alignment of the car??? Or is there a better way to do it???
    Racing a Honda is like running in the Special Olympics, even if you win you are still retarded.....;)
  • Raxe
    • 5346
    There is a much better way.
    Premium Quality Suspension Components
    • deutschman
      • May 2008
      • 5958
      you are going to need new struts if you lower your car and you have the stock struts. the stock struts wont put up with the cut springs. they will blow out.
      • deutschman
        • May 2008
        • 5958
        http://www.hrsprings.com/
        +1
        do it right. do it once.
        • Danny
          • 14216
          If you do it your life will be filled with ridicule and sadness from that point forward.
          • E30-ICEMAN-E30
            • Jun 2008
            • 3
            hey thanks for the feed back. i was going to do it the cheap way but, i guess do it right do it once-(a smart man once said that).
            • CorvallisBMW
              Long Schlong Longhammer
              • 13039
              Originally posted by deutschman
              you are going to need new shocks if you lower your car and you have the stock shocks. the stock shocks wont put up with the cut springs. they will blow out.
              Fixed. The struts don't have to be changed at all unless you're doing coilovers. It's the shocks that have to be paired with stiffer/lower springs.
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                No, don't cut your springs, this is not a Honda.
                And, CorvallisBMW, your sig offends me and my religious beliefs by poking humor at REAL scriptural references.
                OK, maybe not. I just don't understand it.
                • CorvallisBMW
                  • 13039
                  Rocker arms. That's all I'm gonna say.
                  • E30-ICEMAN-E30
                    • Jun 2008
                    • 3
                    hahahahaha!!!!so i did it and i did it the cheap way!!!! basically i cut about a coil and a half out. then i made a cup that had a spiral in it so that the spring would still sit the same as before. And believe it or not but it actually worked and i love the way it rides!!! it is a little bit stiffer than before but that is what i wanted, it helps in taking corners. so i say hahaha to all the haters and doubters!!!! i will post pictures soon!!!
                    • Wishno87
                      • 6025
                      Your sig makes me lul.
                      And no on cutting the springs.
                      • asubimmer
                        • 6482
                        "cutting a spring is like running in the Special Olympics, even if you win you are still retarded.....;)"
                        fixed your sig for you
                        • Danny
                          • 14216
                          I stand by my statement.
                          • kronus
                            • Apr 2008
                            • 13032
                            in before people claim that cutting springs doesn't change their rate.
                            cars beep boop
                            • Stephen
                              Шлем ишака
                              • 10774
                              Haha.
                              Does it? i dont really understand
                              But i do know aftermarket springs are better
