I know that there has been some discussion here about using e36 control arms for a 5 lug conversion, but it appears that a car that I recently bought in Las Vegas is using them with 4 lug spindles to get more negative camber. Is this a commonplace technique?
I bought the car about 9 months ago as a basket case since the timing belt had destroyed the head. I finally got around to replacing the head this week and started looking the car over. As near as I can tell, it has an H&R Premium Coil Over kit, an Eibach Pro adjustable sway bar kit with 20/16 mm bars. And, it has some 16 inch Borbet rims. There seems to be considerable negative camber in the rear, but there are no modifications there to adjust camber and toe in, so I assume the negative camber results from lowering the rear end. On the front end, however, there is considerable negative camber which comes from a longer control arm. The arm is about a half an inch longer than any other e30 that I have measured.
Any comments on this setup would be appreciated.
