I reread the whole thread as I felt I was missing something. My conclusion is that you are using the wrong medecine for the wrong reasons. And not thinking properly. In fact you don't need springs to push the inside wheels down, you need a spring rate that will make the outside suspension push up, and prevent body roll.
If you want to keep the inside wheel from lifting, then you should keep bodyroll at a minimum by raising spring rate, and fine tune with swaybars (but carefully), or lower your roll center by dramatically modifying your suspension geometry.
What is your fronr and rear rates? What tires do you use? What other suspension mods do you have?
