So i was told my 325i had 400f 700r gc's in it when i bought it. It has adjustable camber plates and offset cab's and adjustable koni's all the way around. Well come to find out i ended going with 6" springs because my 5" inchers out back kept bottoming out on this one damn drop on my way home from work everyday. Well when i went to switch in my new springs, i had mismatched 550 and 500 rear springs and not the 700's i was told. I am now looking to get new front springs to match the rear rates i bought. So from what ive read on here people would say that a 450 front with no rear bar would be a happy set up with a little bit of over steer? I don't have money for good sways right now and would just like to get the car set up right and ive read that 700 should be enough rear spring to not run a rear sway. Any help would be appreciated. Thanks :D
Shitty Spring Situation
89 325i parts car
90 325i in progress
ground control 400f 700r-koni adjustables-koni adjustable sways-reinforced control arms-ground control camber plates-e36 cabrio shock mounts-4.10 lsd-5 speed swap in the works
--tryng to join the schwarz army one day at a time--sigpicTags: None -
You will have to ask him but from my understanding the fastest autoxer in an E30 has spring in back that MATCH the front....Something like 500/500, a 25mm front bar and no rear...
'may' be a 500, 600 with no bar....
Some things that you do up front will loosen the car up. The big front bar, camber plates and plenty of negative camber will make the car more prone to oversteersigpic
88 325is -
I have searched the subject, no one else had any opinions here?89 325i parts car
90 325i in progress
--tryng to join the schwarz army one day at a time--sigpicComment
If I werre you I would save the most money by buying just ONE 550lb rear spring and matching that with your 450lb fronts...
Pick up a big bar for front roll resistance/camber control and your done...
If you track or autox the car I'd look for some camber plates to finish it off.sigpic
88 325isComment
Ttt89 325i parts car
90 325i in progress
