As I understand things, you are supplied with 450lb springs, Vorshlag plates, and VW short body inserts....
Awhile back community member Stuck mentioned that he has no issues with the spring dropping out of position when the car is jacked up.
So in checking with all other C3 users, what is your front setup?
How much lower than stock are you?
How far down the adjuster are you?
How much did you shorten the strut housing?
Finally if you have them, can you post pictures of the cars spring setup when jacked up?
I'm looking to juggle shortened strut housing length, and spring perch/adjuster position to not need any helper/tender springs.
FWIW I'd like to shorten my housings 3" and run a spacer of 1" on the top side of the insert.
This will mean I simply won't just cut off the seat and drop the adjuster on top of the remains....It can go ANYwhere.
