Rear Subframe mounts.
    In the 3 years of owning my car I have gone through 2 sets of rear shock mounts.
    Can anyone recommend a brand or style that will not fail?
    Instagram
    Current: 99 M3
    Past: 84 325e, 84 528e
    i recommend the polyurethane shock mounts...I believe that Turner sells them OR you can call up Patrick @ BMA can get em for like $95.
    I've had these mounts for 2 years and I have had no issues :)
    I would blow the mounts every winter!
      I have poly ones from Bavauto. They probably aren't the best ones out there, but they work well so far.
      Project M42 Turbo
        What about E36 rear mounts. Aren't the OEM's better than the E30 OEM's
        Originally posted by Nicademus
        My car beats off to that car. :bow:
          I thought the trick was e46 cabby rsm's?
          Thread title doesnt match the first post, ftl.
            Rear shock mounts or rear subframe mounts? Title says one thing, message says another.
            I use these rear shock mounts and they're working great.
            JT Rear Shock Mounts
            Mike
            www.purems.com |Temecula, CA | 866-397-5487
              Make sure you are installing them correctly (mainly the order in which it came apart), Improperly installed RSM's blow in no time.
                I like the GC ones because they come with a brace
                and unbolt from outside the car.
                  Yeah i goofed on the title.
                  Thanks for all the replies.
                  Instagram
                  Current: 99 M3
