Will 325i springs work on a cabrio?
  • mikekristine325ic
    • Nov 2008
    • 338
    I'm sure its been posted before, however i can not find anything on it.
    I am looking to run bav auto sport springs on my cabrio. Will it work?
    sigpic...
    1991 325is- Current Project w/ 150k on the clock
    1990 325ic- SOLD w/425k on the clock and still ran!
    1985 528e- SOLD
    1972 2002tii-Should have never sold it!
  • Stevie30
    • Apr 2007
    • 1534
    They will fit just fine. My Eibachs were originally on a 318i.
    1991 325ic and 1991 318is
    • mikekristine325ic
      • Nov 2008
      • 338
      Sweet thanks.
      sigpic...
      1985 528e- SOLD
      • dj01540i6sp
        • Jan 2009
        • 349
        I've got a Cheep Question? 318 Springs on a Vert you say- Works/Lowers it. Would a set of ''I'' / ''E'' Stock Springs do the same? I know Verts are Heavier which would achieve a lower stance because of the weight difference approximately 800lbs but would it be To Low for Stock Vert Shocks? and What would it do to the camber issue?
        thax
        dj
        • Wh33lhop
          • 11705
          Your wheel rate will be significantly down from a 318i and you'll be quite a bit lower as a 318i is ~2400lbs and a cabrio is ~3000lbs. That's a huge weight difference. From a regular 325i (~2800-2900lbs) you might be able to get away with it.
          Personally I would go for springs designed for your car. Do it right the first time.
          paint sucks
          • NC325iC
            • Mar 2004
            • 6565
            the problem with using non vert specific springs is the rears will sag more than usual
            vert specific springs have higher rear rates than coupes/sedans
