Threeouse AND camber plates
  • pegase747
    • Jul 2006
    • 279
    Hi all,
    just wondering if you can use the THR CAB to increase caster, AND at the same time use Camber plates to increase camber ??
    Will that be over-something ?
    Like will the extra-camkber added to the extra-caster might affect the ride/handling in a bad way ??
    Anybody have both can let me know ??
    Regards from France / Pierre
    1988 E30 ALPINA B3 2.7 #224/257 Made in Buchloe
    see more : http://www.r3vlimited.com/board/showthread.php?t=71686&referrerid=12460
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    You can certainly use both. Since the camber plates allow you to adjust both camber and castor, you can dial in exactly the suspension you want. Both are very nice upgrades for e30s.
    • Knockenwelle
      • Jul 2008
      • 395
      I'm considering swapping the M3 CABs I currently have on my car for the Treehouse Eyeballs. Anyone know if the dimensions (read: effective caster) is the same?
      Mike
      '91 325i track car. Mostly...
      • CorvallisBMW
        • 13039
        I believe they are nearly identical. The THR CABs are much firmer though and will create more NVH but better handling.
        • Knockenwelle
          • Jul 2008
          • 395
          Cool. I'm a sucker for NVH...
          Mike
          • Monteblanco
            • 14
            so if i get a cup kit or coil overs do i need to get camber plates?? cuz the camber plates ive seen for sale are like 300 bucks and i dont want to drop like 700-900 bucks on a coil over or cup kit set if i need to drop another 300 on camber plates!
            WTB: 4door cardinal red interior
            Having a fast honda is like coming out of the closet.....you suprise everyone at first, but in the end you're still gay.
            • Erick
              Official R3V Drifter
              • 11169
              I can vouch for that.
              I have AKG 75D Poly M3 CABs on my turbo car... and the 318iS I bought has the THR CABs. The 318iS is more harsh than the 325i on the bumps.
              Go figure. If my turbo car had A/C I would prefer to daily that instead :p
              ..::Support FullOpp::..
              FullOpp Stickers for sale!
              Feedback Thread
              • Massive Lee
                • Sep 2006
                • 6785
                Hi Pierre.
                Extra caster is always good for high speed stability and improved cornering. Extra camber on the other hand will have side effects. While it will increase contact patch on the ground when cornering, it will also wear the inside of the tires if you only use your car as a street car... If you exclusively use your car as a daily driver, I would suggest not to add extra camber...
                massivebrakes.com
                • daniel
                  • 6703
                  what is nvh, i couldnt figure it out. something something handling
                  depending on how low you go, and how much you care about tire wear, then you might need camber plates and even a rear camber adjustment kit thing.
                  i wouldnt recommend the cup kit though.
                  http://instagram.com/dslovn.drives
                  • gearheadE30
                    • Jun 2007
                    • 3734
                    NVH=noise vibration harshness
                    Project M42 Turbo
