Today I replaced my tie rods. I test drove it to see if I measured the length of each side correctly. The car doesn't pull, but when my steering wheel is positioned in center the car drives to the left. But when i position the steering wheel so that the car drives straight, it looks like my steering wheel was put on crooked, (it is an aftermarket steering wheel so I could have possibly installed it crooked originally). The reason I am concerned is because before this install I never noticed my steering wheel as crooked as I see it now. If it doesn't pull Should I dish out the $70 bucks to have the car aligned?
Tie rod replacement and possible alignment issue
I spent $49 on each assembly. Then nobody had the rubber boots so I had to go to the dealer. Cost me another $50 for the rest of the hardware. I read a DIY article on e30tech and I decided I should get everything they said to get. I also didn't want to get the $40 sets from ebay because i heard terrible things about those brands.
I know you are trying to save money by doing yourself but now it is time to get it aligned. It might not pull hard to one side or the other but it still needs an alignment. If you turned one tie rod half a turn to far or not far enough it can be out of spec.
Take it to a shop and tell them you just want the front toe adjusted. That is the only alignment adjustment that can be made to a stock E30 (You can add aftermarket adjustments like camber plates and stuff).
Nothing can be adjusted in the rear and only toe can be adjusted in the front. Don't pay Les Schwab to adjust things that can't be adjusted.
- KeananComment
