I went to pull a e36 318i PS rack and there was some oil in the boots. Not a lot but about a shot glass or 2 worth. Is this rack worth $40 to do the swap?
How much oil is allowed in the rack boot
The seals are definitely bad. Eventually it will leak out of the boots and all over the ground too, leaving a mess wherever you park. Either run it with manual steering until you find a nice sealed rack just so you have the conversion done or wait, because it isn't worth running ps with bad rack seals.Comment
To run it without power steering, you still need the rack itself filled with oil to lubricate it, so running a leaking rack like that would be worse than running a leaking rack with PS.The seals are definitely bad. Eventually it will leak out of the boots and all over the ground too, leaving a mess wherever you park. Either run it with manual steering until you find a nice sealed rack just so you have the conversion done or wait, because it isn't worth running ps with bad rack seals.Comment
What I meant was that you can run the rack with no ps pump belt, but keep the lines and reservoir. this means that the rack will still be lubed but the seals won't be under pressure. This is how I ran my old leaky rack. Sorry for not making that clear.Comment
No I understood it, I just like having PS. My first 318i M40 had no PS and no PW or PSunroof. This car has it all and I like the luxury. I'll just keep looking for one. Thanks though.Originally posted by NicademusMy car beats off to that car. :bow:Comment
