Scalloping front tires. HELP!
  • deansbimmer
    • 674
    I'm at my wits end with this. I haven't been stumped like this in a while. My front tires are scalloping on the inside, on both driver and passenger sides. The whole front end is new. I cannot find anything worn out. In picking up the car and trying to move the front wheel assembly, it is rock solid, nothing moves.
    In about 5k miles, the new Eagle F1 front tires have been worn down to less than 1/16" tread in the scalloped area! The toe is adjusted as close to zero as possible, but it feels as though it may have a bit of toe out. The car pulls straight ahead with no shimmies or vibrations at any speed.
    WTF!! F(&%$(@#K :hitler:
  • E30_Pare
    • 7801
    maybe your rubbing.. spacers?
    DREWLIENTE
    1$ PShops PM me
    • deansbimmer
      • 674
      No rubbing anywhere on my car. Yes, running 10mm spacers (only to be able to clear the brake calipers). This is the tread face scalloping, not the sidewall. :(
      • theox69
        • May 2008
        • 1732
        maybe they rub on the inside when you're turning?
        you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
        • deansbimmer
          • 674
          There is absolutely no rubbing anywhere at anytime.
          • DCColegrove
            • 2748
            Tire is bouncing be it from bad dampening or ballance...
            This will also happen with bad ball joints or other loose shit in the suspension.
            Toe out will shred them as well.
            • E30_fiend
              • Apr 2006
              • 7348
              i would say abnormal premature tire wear due to a manufacture defect. and i have one question, did you by chance replace the upper strut mounts?
              • E30_fiend
                • Apr 2006
                • 7348
                he already said his whole front end was replaced. that narrows it down to balance of wheels. but if you think about that, he would feel that in the steering wheel for sure.
                • deansbimmer
                  • 674
                  This is why I'm stumped. The shocks are Koni Yellow adjustables. Set on stiff. 450lb front springs. I bought the suspension setup used from a board member, so with the unknown history of the shocks, it may tempt me to suspect them. I'll pull them out this weekend and inspect them. How much would sending them off for rebuild cost?
                  The CABs, arms, tie rods, and all other bushings/balljoints are new. New Vorschlag camber plates on top.
                  The tires have exhibited heel/toe wear since new. I even had it "professionally" computer alligned, but that seemed to accelerate the wear, so set it back to as close as possible to 0 as I could, which helped with the heel/toe wear.
                  I feel no bouncing whatsoever in the front suspension which may or may not rule out worn struts, but I do notice that the suspension bottoms out more easily than I think it should for being set as stiff as possible. AARRG. I have about 5K miles on this suspension since buying it used.
                  • DCColegrove
                    • 2748
                    Just looked at the tyres... Didn't really read it (learned that here on R3V).
                    Still think it's the struts.
                    • Danny
                      • 14216
                      Tyres? GTFO you british kook.
                      • DCColegrove
                        • 2748
                        Whoops slipped out there... Goes along with kerb...
                        Spent too much time in Europe.
                        Tires.
                        • deansbimmer
                          • 674
                          Sonofabitchgawdammit. Time for new thread: How to determine if my struts are blown. :(
                          • DCColegrove
                            • 2748
                            Try setting the toe in like 1/16" first. Neg camber and toe out will shred them and with an aggressive tread it can do that scallop as well.
                            • Stephen
                              Шлем ишака
                              • 10774
                              Push down on them, and look at the rebound... Its not precise but its easy. And check for oil on them
