I own a 318i Cab and I have purechased a set of Eibach Pro springs for a 325 i Cab. The kit for the 318ic is similar with the same springs in the back but different springs in the front. The 318ic kit is no longer available.
Can any body tell me if they have experience with the 325ic kit on a 318ic? I expect the front will sit a little higher and be a little stiffer. Below are the specs for the front springs but I'm not savvy enough to make sense of them. Any help is appreciated.
spring 325 305mm 318 279mm
12.5 mm/21 Newton 12mm 20 Newton
or 119 lb per ft or 114 lb per ft
Eibech Pro kit#
318ic = 2010.240
325ic = 2010.140
Eibech Pro kit#
318ic = 2010.240
325ic = 2010.140
