How to best adjust sway bar links?
  • hispeedimports
    • 219
    I have a set of front and rear ST sway bar kit, with IE front adjustable links,
    what would be the best way to adjust the links?, front and rear are adjustable,
    Thanks, Mario
    dtireshop.com@verizon.net
    I'd suggest that you adjust the end links so that the sways are level or angled slightly down when the car is resting on the wheels.
    • 1990m3
      • 1180
      it's easy if you have some ramps you can drive on, or at least a couple of 2x4's to get some ground clearance so you can reach under the car
      • SkinnyVT
        • Nov 2008
        • 391
        ^+1, the car needs to be resting on the wheels (on a level surface) when you are adjusting the links. Disconnect one side, adjust the other side so that the bar is level/just below level when on the wheels and then adjust the disconnected side so that it slips right into the hole without any force.
        '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
        • hispeedimports
          • 219
          Thank you guys,
          good feedback, that is all I needed to know,
          Thank you all very much, Mario
          • hispeedimports
            • 219
            Well I did the rear, with angled slightly down,
            but there is not enough space to adjust the front bar level or angled slightly down when the car is resting,
            with the links adjusted to the max the bar is angled slightly up,
            any recommendations?
            • TrentW
              • 2815
              I'm going to be doing this soon also, so do you need all four wheels blocked or just the fronts?
                That will be fine.
                You can do it with only one end up, but it would be best to have the car level.
                • TrentW
                  • 2815
                  Originally posted by jlevie
                  That will be fine.
                  That's what I thought--thanks a lot for the confirmation!
                  • hispeedimports
                    • 219
                    [quote=jlevie;1428588]That will be fine.
                    Thank you very much,
                    Mario
