Replaced Front Shock Mounts...Still Hear Knocking Up Front...
  • Bimmerista
    • Nov 2005
    • 5425
    Last week I got the front shock mounts replaced. The knocking sound is still there on the passenger side. I do know as a fact that my front shocks are blown, but really haven't stepped up to the plate to buy a set of Bilstein Sports just yet.
    Are the front shocks to blame?? Any idea what else I can look into?? TIA
  • thereisnoyun
    • Feb 2007
    • 2301
    maybe the spring was install inproperly, and its crooked and not on the bevel.
    • Bimmerista
      • Nov 2005
      • 5425
      Well...it was making noise before I replaced the mounts as well. I was there when holding the spring compressor when it was installed, lets just say that everything was installed correctly.
      What else could it possibly be?? The bearings were also greased up pretty well.
      • a_thomasmr23
        • Nov 2008
        • 152
        when does it make the knocking sound on bump? or the on the turn?
        bring it http://athomasmr23.mybrute.com
        • Bimmerista
          • Nov 2005
          • 5425
          Well...the thing is, the sound comes and goes. I can drive on the smoothest roads & I hear it.
            Bad shocks, bad control arms, sway links or sway bushings are all candidates.
            • sticksdaman
              • Apr 2005
              • 2987
              I would say sway links or, if not already replaced, Control Arm Bushings.
              Originally posted by ebelements
              Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
              • Liam
                • 753
                Also check the gland nut that holds the shock cartridge in the strut for tightness.
                I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
