No power steering fluid ?
  • Jordan325iC
    • Aug 2005
    • 1697
    My e36 steering rack that I installed leaks very badly. The rack is junk as far as I'm concerned, so I decided to just remove the PS belt and let the fluid leak out for a temporary solution. At this point, I don't believe there is any fluid in the rack.
    Been running it for a few hundred miles already. How long can you run a power steering rack with no power steering fluid before it stops functioning?
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
  • E30Eric
    • Sep 2007
    • 156
    It will go for a while, but the fluid is there to lubricate it. As long as road gunk is not getting in the rack you will be ok. I hit a nasty ice chunk and it put a hole in my pan and made the steering rack leak also. I just took the belt off and have been running for at least 1k miles with no problems. Enjoy the workout parking the car...
    1988SuperETA|Full I component swap|19lb injectors|Schrick 272|MSIIExtraBeta20071020|GM DIS Wasted Spark|LC-1
    • E30_fiend
      • Apr 2006
      • 7348
      where is it leaking from?
      my buddy had a real bad leak and he just cut the belt. he hasnt had any problems either. i made a couple of those power steering deletes like a member on here was selling and i gave him one and he removed the ps lines and no more problems
      Taylor
