SO, I've done some reading and searching around and have a few questions. I have a 92 325ic if that matters. At some point soon, I'm going to completely go through the suspension. The car is a daily driver...
1) What are the best bushings? Powerflex? Things that are determining factors for me: NO SQUEAKING. Low/no maintenance. Durability.
2) What all should be replaced? I plan on doing a z3 steering rack at the same time...As with everything I'm doing on this car, I want to do right and do it once. Here is what I have so far. Just cut and pasted from an old list I made, not sure if it is complete and/or the best choices...
Eibach sways
lower control arms
bracket w/out bushing for control arms
spring pads
bushing set for rear trailing arms
shock mounts
gaskets for shock mounts
cover cap for strut mount
shock/strut mount nut
bolt for rear shock to control arm
plate for rear shock mount
front strut bearing
rear subframe bushings
upper front strut mounts
3) I'm liking the h&r sport/bilstein sport combo, with one exception. The reverse rake. I will shortly have add'l weight in the trunk so it will be even worse. Is there a fix for this? Is there a different combo that will provide similar performance and ride quality? I don't mind firm, but I don't want back breaking. I want that front low, but don't want to worry about hitting shit. Been there, over that. I'd like to avoid coilovers if possible.
Uh I think that's all my questions for now. Thanks!
Eibach sways
lower control arms
spring pads
shock mounts
front strut bearing
