Wide 205 50 16's to fit 7.5"-wide wheels?
  • mach schnell
    • Apr 2008
    • 1059
    What are some wide 205 50's to fit 16x7.5" wheels? I don't want to run 225 45's, and I like the stock overall diameter. I also want the minimum amount of stretch.
  • daniel
    • 6703
    225/45-16's have the essentially the same diameter as 205/50-16's. for the minimum amount of stretch, run 225/45-16's. but if you really don't want to run 225's...
    http://instagram.com/dslovn.drives
    • mach schnell
      • Apr 2008
      • 1059
      Yeah, there aren't many 225 45 tires out there.
      And I'll be running these on a 318, so I don't want the extra weight of a heavier tire.
      • straight6pwr
        • Sep 2004
        • 3450
        i love my 205/50/16s.
        pic for reference, its just baaaaarely stretched:
        • mach schnell
          • Apr 2008
          • 1059
          Good pic, thanks!!!
          What tire is that?
          • Hodge
            • Jun 2008
            • 424
            That is not stretched at all.
            E30- 1989 325is
            • straight6pwr
              • Sep 2004
              • 3450
              Originally posted by mach schnell
              Good pic, thanks!!!
              What tire is that?
              toyo proxies t1-r
              well the sidewall is leaning in from vertical, so falls in the category of stretch, but like i said baaaaarely. you dont really notice, which is good.
              • shmutzigE30
                • 1680
                put 195's on a 7.5 inch wheel. then youll get a little but safe safe and noticable strech
                AW 89' 325i Vert - SOLD
                • daniel
                  • 6703
                  uh no
                  • Hodge
                    • Jun 2008
                    • 424
                    Stretch occurs when the width of the tire is less than the width of the wheel.
                    7.5" = 191mm
                    205 tire = 205mm
                    Not stretched.
                    E30- 1989 325is
                    • mach schnell
                      • Apr 2008
                      • 1059
                      7.5" = 191mm
                      205 tire = 205mm
                      Not stretched.
                      Yeah, but not all tires of an advertised width (such as a 205/50/16) are the same in ACTUAL width.
                      For example, anyone who has run R-compounds will tell you that Hoosier's are ALWAYS very wide....
                      .... so a 205/50/15 Toyo RA-1 is NOT going to be as wide as a 205/50/15 Hoosier.
                      In fact, a 205/50/15 Hoosier is going to be as wide (if not WIDER) than many 225/50/15's.
                      That's why I posted the question.
                      • Hodge
                        • Jun 2008
                        • 424
                        I know this. Different tire manufacturers vary on the "listed" width.
                        I was speaking theoretically, where 203mm is smaller than 205mm, so a 205mm tire will not stretch on a 203mm wheel.
                        For example, I had 15x8 wheels with 205/50/15 tires. Yeah, the tire curved slightly, but it was by no means stretched. A different 205/50/ tire may have stretched or may have been poofy.
                        E30- 1989 325is
                        • mach schnell
                          • Apr 2008
                          • 1059
                          Visually, if the tire's tread is not "squared off" with the width of the wheel, then I think most people will refer to that as stretch.
                          Anyway...
                          ... who knows which 205's out there are the wider ones...?
                          • daniel
                            • 6703
                            the aspect ratio also determines how much "stretch" (looks wise) you have.
                            • vivalegreg
                              • Apr 2006
                              • 1313
                              pics of stretched tires go!
                              e30s r kool
