Where can i get corrado steelies widened?
  • brn2ply7
    • 301
    I have a buddy with 15" corrado steelies and he might be getting rid of them. Does anybody know of a company in the washington d.c area that would widen the wheels. Im guessing if i added about 1.5" to the lip the would sit about right on an e30. I know the stellie thing has been beaten to death but i do appreciate oppinions.
    89 325i parts car
    90 325i in progress
    ground control 400f 700r-koni adjustables-koni adjustable sways-reinforced control arms-ground control camber plates-e36 cabrio shock mounts-4.10 lsd-5 speed swap in the works
    --tryng to join the schwarz army one day at a time--sigpic
  • bad_azz_bmr
    • Sep 2004
    • 433
    i don't know if they are going to work out on the e30, from what i have heard vw's are lugcentric and not hubcentric i think that applies to there steelies as well, i don't know how tight they will fit over the hub and if they will stay centred, best bet is to try them first before widening.
    • Massive Lee
      • Sep 2006
      • 6785
      4 x 100 VW wheels share their center bores with 4 x 100 BMWs: 57.1mm
      Both are hubcentric
      massivebrakes.com
      • e30this
        • 3580
        They will fit fine. Check Vortex for someone to widen them. I think when all said and done its going to cost you about 500...
        • brn2ply7
          • 301
          Thanks. Im trying to decide between euro weaves, koseis, widened stealies, and ronal turbos. its an ongoing back in forth in my head
          89 325i parts car
          90 325i in progress
          • JRKOUPE
            • Dec 2004
            • 3159
            geez.....thats scary...
            • asubimmer
              • 6482
              turbo's end of story...
              • RobE30
                • 959
                Let me know if you do not decide to run the steelies. I really want to do the corrado brake upgrade (front) but want a 2nd set of wheels for winter. 14's would be out of the question b/c of the 'rado brakes. Def check out vortex for more widening info. Look up Nothingleavesstock guys name is Josh. I've been good friends w/ him for years, he has a vw shop near Allentown Pa (all sorts of custom stuff) and could probably direct you to a trustworthy person near you. Good luck w/ your decision....euroweaves ftw
                09 BMW 328xi touring 6spd
                05 Subaru Outback XT 5spd
                87 BMW 325is
                a few bicycles
