I think it might be the 20mm spacers I have fitted so the 330mm brakes and 4 piston AP 5000+ Callipers clear. :P :P
As can be seen the rear isn't an issue we have plenty of clearance there, but the front the fenders lips are resting on the top of the tyres. I see loads of pulling and cutting in the future, and these fenders have already been pulled 3cm wider.
Reason the ride height is so low.
We have the correct geometry to run it that low from the tubular arms, still need to fit thr E46 330i rack, bump steer spacers and longer spherical bearing rack ends.
Should have the car back in 2 weeks, pictures to follow of the body work.
