front tire rub!!
  • mrhinton
    • Nov 2008
    • 157
    front tire rub!!
    im running some type of eibach springs with 17x7.5 rims. fronts are 225/45/17 rears are 215/45/17. my rears rubbed for a second until i bashed the rear quarter panel. i tried the 225s in the rear but then rub something ridiculous. i could raise the car to run the 225s but ill do that later.
    my issue is that my fronts are rubbing on hard cornering. is there anything i can do to combat this? they rub on the inner wheel well. what can i do? should i raise the front? should i try to space the fronts out more? help!!
  • atomic
    • Jun 2007
    • 5691
    Maybe try a correct tire size and go from there....
    • erik325i
      • Jan 2005
      • 3567
      +1
      Your tires are way too tall. Get proper tires.
      Erik
      • mrhinton
        • Nov 2008
        • 157
        225/40 or do i have to go with 35s?
        • daniel
          • 6703
          225/40 is closest, or 215/40 would probably be better for you because of rubbing issues.
          what offset are your wheels?
          http://instagram.com/dslovn.drives
          • mrhinton
            • Nov 2008
            • 157
            i dunno the offset right now. gotta check. 40 maybe? they bolt up without spacers or anything.
            • z31maniac
              • 17566
              215/40/17 is as close to stock OD for 17".
              I'm running 17 x 8 ET 25, with wide 215/40/17s and have no rubbing, and my car is pretty low on coilovers.
              Although it does feel like the fronts have been heavily rolled.
              www.gutenparts.com
              • erik325i
                • Jan 2005
                • 3567
                The bad thing about 17" wheels is there is not a huge selection of tires that fit for our cars. 215/40-17 is the closest. 225/40-17 is a little tall, but would work. Only one or two companies make a 225/40-17 though.
                Erik
                • atomic
                  • Jun 2007
                  • 5691
                  And if the wheels are et40 you would likely need to use 15mm spacers and be in the et25 range along with the 215/40-17 to avoid rubbing. I am running H&R races with 17x8 et20 wheels with 215/40-17 and do see some slight rubbing at full lock on the inner fenderwells. I also do not have rolled fenders and do not see any rubbing in that area whatsoever...
                  • Kingb
                    • 928
                    I am running IE3's with 17X7.5 et 25 I had 225/45 on the rear but I rubbed a little and the front had 215/45 so I put the 215's on the back and put 205/40's on the front. perfect
                    Originally posted by Nicademus
                    My car beats off to that car. :bow:
                    • mrhinton
                      • Nov 2008
                      • 157
                      yea i had the 225/45s on the rear and they would rub over bumps or anything of the sort. i put the 215/45s on the rear and 225s on the fronts and now they rub at full lock. i dont wanna scrap the 225s because they are brand new tires.
                      • mrhinton
                        • Nov 2008
                        • 157
                        what would happen if i put spacers on the front while leaving the rear the way it is? i heard it was a bad idea. any ideas on that?
                        • mrhinton
                          • Nov 2008
                          • 157
                          i know someone has an opinion on this.
                          • 92 mtechnic cabrio
                            • 4907
                            It will look wierd if the difference is more than 10mm from front to back. But should not adversely affect your car's daily driving ability.
                            R.I.P 07/01/09 - 04/23/10 :(
