Maximum wheel / tire size without rubbing?
  • MaloventEvil
    • 248
    What is the maximum Wheel/Tire width without rolling fenders (for both the front and rear)? What is the max with rolling fenders?
    edit: i also searched, but it is hard to look at a thread with 2000+ replies :)
    Thanks all,
    Aurash
  • atomic
    • Jun 2007
    • 5691
    There are to many variables to answer that vague question. Depends on wheel offsets, suspension setup etc etc...
    :up:
    • MaloventEvil
      • 248
      I was thinking of running the ground control complete coilover kit with smaller spring perches, and shortened front strut housings. I really wanted to know what the maximum width I could fit in without rubbing would be with that setup -- sorry for not being more clear :D.
      Would I be able to fit 16x8.5's all around?
      -Aurash
      • erik325i
        • Jan 2005
        • 3567
        Still depends on your ride height. Using coilovers doesn't tell us how low you will be...
        -Aurash
        Of course this wheel size will fit. It depends on the offset and tire size.
        There are so many variables, nobody can tell you the "widest tire without rolling".
        Erik
        • bmw325csi
          • May 2007
          • 4045
          you can even put some esm 16x9's
          harry/harout
          • daniel
            • 6703
            if you want to go that wide, you will probably need to roll your fenders.
            http://instagram.com/dslovn.drives
            • MaloventEvil
              • 248
              Erik
              well then, how about... what is the widest tire i can run without issues on the stock suspension. basically i need new wheels, and i want to know what i can order reasonably without issues. if you have any known sizes that fit certain setups please let me know. :)
              • atomic
                • Jun 2007
                • 5691
                /thread
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  225 is easy. 235+ requires concentration.
                  • MaloventEvil
                    • 248
                    excellent. so i will target 225's for now then! :D
                    thanks for the information!
                    -aurash
