Offset
  • D-rock
    • 714
    Offset
    Hey guys. I just got this car and it has a 5 lug conversion. Now i think they are from an e36 im not to sure. And neither was the guy i bought the car from. I know the lug pattern is 5x120. I was wondering what would be the maximum offset i could get on a 16 without rubbing?
    Thanks a lot for the help!
  • Wh33lhop
    • 11705
    Depends on which conversion you're running.
    paint sucks
    • D-rock
      • 714
      I'm not sure anyway i can find out?
      • Gooch
        • Dec 2006
        • 1674
        E36 five lug stuff requires high offset wheels (which those style 68's are) so unless you have some rather large (i.e. 20mm) spacers, then you're most likely running e36 stuff and not e30 m3 stuff.
        '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
        '87 535i - Vacuum brake conversion [SOLD]
        '93 525iT - 5-speed swap - 320k and counting
        '09 328xi - 6-speed
        • daniel
          • 6703
          gooch is right. unless you have some fatty spacers, then you have the e36 setup. ideally, the offset of any wheel you put on there should be really close to ET40, but I am running ET23 wheels on my e36 setup.
          http://instagram.com/dslovn.drives
          • D-rock
            • 714
            Thanks guys!
            Well there are no spacers.
            So what would be an ideal poke offset. That would not rub?
            et 10 ?
            et 20 ?
            • D-rock
              • 714
              up!
              • Gooch
                • Dec 2006
                • 1674
                Send Mystikal a PM or post in the sticky at the top of this forum section, I'm sure he can be able to help with your question.
                '09 328xi - 6-speed
                • D-rock
                  • 714
                  I tired that he was not to sure..
                  • Jonny Cash
                    • 1763
                    Sell the car to me, and dont worry about it :)
                    Honestly. Check the offset on your current wheels. I have no idea what "poke" means, but you should have decent fitment with a higher offset. I would say 35-45mm.
                    -Jay
                    2014 NASA FL se30 champ #81
                    2001 se46 3 year plan in progress
