Intermittent front wheel vibration?
  • jeffluvse30s
    • 60
    Holds straight most of the time but occasionally begins to shake erratically. Not sure if it makes a difference but its an e28. Hypothesis's appreciated.
    - " Ill Never again argue with an idiot. They bring you down to their level and try to beat you with experience."
    http://www.flickr.com/photos/13617577@N04/
  • Asbradley21
    • Jun 2008
    • 1938
    probably threw a weight. Go get it balanced.
    S54B32 swap in progress. Status: Getting There
    • jeffluvse30s
      • 60
      Thanks, just did a few hours ago. Problem continues....? Could it be somethings loose in the steering rack assembly?
      • bimmerboy08
        • Apr 2009
        • 353
        aftermarket or stock wheels?
        • jeffluvse30s
          • 60
          recently switched to 225/60/14 F&R. Stock suspension.
          • bimmerboy08
            • Apr 2009
            • 353
            well if they were inexpensive aftermarket wheels, you might need hubcentric rings, but it sounds like you are still on stock wheels so nix that.
            • Asbradley21
              • Jun 2008
              • 1938
              Might be a balljoint. Jack up the car and start shaking stuff around.
              • jeffluvse30s
                • 60
                Will do, see how it turns out. Thanks again for help.
                • downernsp
                  • Mar 2008
                  • 1932
                  low speeds or high speed?
                  • SamE30e
                    • Sep 2007
                    • 4319
                    Mine does it too and I have brand new ball joints.
                    1985 325e 2.8 Turbo VEMS
                    • Naplm00
                      • Nov 2008
                      • 1573
                      mine was caused by worn out Control arm bushings and worn tie rods
                      88 325ic ~~~> Rusty and ugly
                      85 E ~~~> RIP
                      • quickervicar
                        • 1197
                        My Rabbit's was a worn tie rod.
                        • jeffluvse30s
                          • 60
                          Didnt get under nor did it happen at all today. Varies, 30-60 and or 60+mph. Stock e21's. Control arm bushings are solid. Tie rods could use replacing.
                          • graphikg
                            • Jan 2008
                            • 1614
                            Or it could be the problem I have. Warped tires.
                            • jeffluvse30s
                              • 60
                              With your tires isnt it consistant?
