Hey gettin some 15/7 beyern wheels soon.. I have stock suspension at teh moment and dont have the money to chang it right now. SO is any one running stock suspension with 15s and if so post a pic? and what size tire you are running so i can go ahead and start look. Eventuallly ill lower it an inch or so... Thanks
15s with stock suspension.. what size tire??
Tags: None
205 55 is the correct size for 15" wheel. But depending on offset you may be able to run a 215 - 225 tire.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827 -
Check the wheel, should have offset listed.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
hell yea i emailed bav auto and the guy said they are made specifiacally for e30.. no ring spacers or anything.. use stock lug bolts.. 205/55/15 is correct size! yay
Buy suspension before wheels.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Why ? I cant afford them both. I might get some springs.. But i only want an inch or so drop. i think that will look good
I run 165/50 on 15x8 but I like the stretched look.1991 e30 328i M52 swapped: Gone
1995 e34 540i/6 1 of 76 Clean
1985 e28 euro 525i the dailyComment
