help with tire sizes
  • ROOR
    • 58
    hello, I want to run the following but am having a hard time finding the right tire sizes;
    Rear: 16"x9", +20, yields 228.6mm tire width, what is the widest tire I can go in the rear on this wheel without rubbing?
    Front: 16"x7.5" +15, yields 190.5mm tire width, same question, how wide can I go?
    I've searched and couldn't find an explanation on how much I can stretch tires on a rim, or if you can fit a wider tire on a rim like this...
    Happy Veteran's day.
  • Jonsku
    • Oct 2004
    • 566
    Sure you can fit wider rubber to the rim than the rim itself is. There's a quide for accepted tire sizes on the 'net..
    The rim isn't the problem with tire width, but the car's body.
    Those rims fit nicely with 225/40 in the back and 205/45 to the front. Some spacers might be needed to clear inner side..
    - E34 M5 (x 2) -
    - E30 V8 Cabrio "Kylpyamme" -
    - Alpina D10 Touring #33/94 -
    - E46 318i Touring -
    - Toyota Hiace 4wd -
    • daniel
      • 6703
      it really depends how low your car is. it will look dumb if you have undersized tires and a huge fender gap.
      http://instagram.com/dslovn.drives
      • ROOR
        • 58
        im running H&R Sport and Bilstein
