Help a noob out :D
  • v8fc3s
    • Apr 2009
    • 105
    Help a noob out :D
    I have made the mistake before so I am doing this to make sure. I found rims i want to put on my e30. they are 15X7 with a bolt pattern of 4X100 and a 40mm offset. Will i need spacers or anything to fit these of my car? Thanks in advance.
  • xwill112x
    • Jan 2009
    • 4236
    about 10mm maybe 15 and you'll be right. :up:
    • v8fc3s
      • Apr 2009
      • 105
      but it will still fit right? just be tucked in a little. And under width, it says "7J". does that make a difference?
      • e30_325es
        • 1249
        You need spacers or they will rub the front strut housings.
        • Philo
          Ich esse kleine Kinder
          • 3334
          I recommend 25mm in the rear, and 20mm spacers up front. Or if you have the $, go bigger and get adapters.
          -tim
          Originally posted by Jordan
          I like the stance
          • Stephen
            Шлем ишака
            • 10774
            7J just means the wheel is 7" wide
            • daniel
              • 6703
              if his car is lowered he might need fender rolling to fit that. for just "making them fit", something like 10-15 is much easier.
              http://instagram.com/dslovn.drives
              • v8fc3s
                • Apr 2009
                • 105
                :x this is going to run me more than i thought ($). Aren't spacers like $150
                • daniel
                  • 6703
                  yes. that is why you should buy wheels with a proper offset.
                  • Wishno87
                    • 6025
                    You may need hubrings too.
                    • v8fc3s
                      • Apr 2009
                      • 105
                      what is the proper offset i should be looking for? what is the range... if you will?
                      • xwill112x
                        • Jan 2009
                        • 4236
                        20-30 is desireable for a e30 (non ix)
                        • Slick92GS-R
                          • Apr 2005
                          • 662
                          i run 20mm spacers on my +40mm wheels.. looks like you've shopping at Hialeah Honda ..i'm in Miami.. let me know if you need any help ..
                          the best offsets for E30's depend on your wheel width, 8" or less you should go +18 to +30
                          --Hayden--
                          '87 325 coupe- Trak Rat
                          '93 318is- 4cyl's of fury
                          '92 Integra GS-R--yeah, its fast..
                          www.G2IC.com
                          • v8fc3s
                            • Apr 2009
                            • 105
                            thanks for your help. its just that this is my first car and i wasnt ready to spend that much money but i cant stand the rims i have on it now. I hate them with a passion!:x
                            but after Christmas i will come up with something. thanks for your help guys!
                            it is much appreciated.
                            • daniel
                              • 6703
                              if you hate the wheels, stock basketweaves look fine and can be had for $100-$200.
