185/60/14- I can get for free, is the size ok to run?
  • clydesdale
    • 631
    I was thinking of putting these on my stock weaves for winter tires. I have a friend who had a civic and he has bridgestone potenzas in the above size. I realize the tires is shorter and narrower and the speedo will be off. Has anybody run this size of tire?
  • E30Idea
    • Mar 2007
    • 2196
    of course its ok to run. Unless they are wheelbaroow tires......That would be bad
    ** Lot's of M20 turbo parts for sale.**
    Turn key track car.
    http://www.r3vlimited.com/board/showthread.php?t=222066
    • theox69
      • May 2008
      • 1732
      I actually had those on my car and it sits way too low.
      I was at stock ride height and I couldn't fit a jack under there, even from the side.
      I got some real sized tires with a drop and now its much better.
      you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
      • clydesdale
        • 631
        So if all I have to pay is 40 bucks for the mounting, is it still bad. If the size sucks than it sucks. But if they aren't that bad, I would do it.
        • E30SPDFRK
          • 5716
          Do it, they're free tires.
          Byron
          Leichtbau
          • ethree
            • Aug 2007
            • 1216
            I ran that size for a while with no problems at all. I think your speedo will be off slightly more than it probably already is.
            • Justin B
              Sikky Nar Nar
              • Mar 2005
              • 4273
              Stock Tire - 195/65R14 >Search Tires Tire 1 - 185/60R14 >Search Tires
              Section Width: 7.67 in 195 mm
              Section Width: 7.28 in 185 mm
              Rim Diameter: 14 in 355.6 mm
              Rim Width Range: 5 - 7 in
              Overall Diameter: 23.98 in 609.09 mm
              Overall Diameter: 22.74 in 577.59 mm
              Sidewall Height: 4.99 in 126.74 mm
              Sidewall Height: 4.37 in 110.99 mm
              Radius: 11.99 in 304.54 mm
              Radius: 11.37 in 288.79 mm
              Circumference: 75.33 in 1913.3 mm
              Circumference: 71.43 in 1814.3 mm
              Revs per Mile: 867.3
              Revs per Mile: 914.6
              Actual Speed: 60 mph 100 km/h
              Speedometer1: 63.2 mph 105. km/h
              Speedometer Difference: - Speedometer Difference: 5.453% too fast
              Diameter Difference: - Diameter Difference: 5.18%
              • Adrian_Visser
                • Jun 2006
                • 2823
                where did you get all that info is that from the Tirerack size calculator?
                '89 Alpine S52 with goodies
                • Justin B
                  Sikky Nar Nar
                  • Mar 2005
                  • 4273
                  1010tires.com calculator actually...
                  http://www.1010tires.com/TireSizeCalculator.asp
                  • 884door
                    • Nov 2008
                    • 380
                    I'm running the same size, also got them for free. I can fit a jack under my car and it's pretty low. If you had trouble fitting a jack under it at stock height than you need a smaller jack.
                    Speedo is a little further off than normal, When the Speedometer reads 70 the GPS Reads 66 or 67.
                    • daniel
                      • 6703
                      i wouldn't recommend it for winter tires as you will lower your car significantly with these tires.
                      http://instagram.com/dslovn.drives
                      • VacMan
                        • Apr 2007
                        • 2405
                        Free uber alles.
                        • Mde36
                          • 509
                          i have 185/60's on my bottlecaps now they're.....ok but i wouldn't buy them again
                          Powered By Ford
                          • 884door
                            • Nov 2008
                            • 380
                            Agreed with above, I wouldn't pay for em, but if they're free go for it. Honestly I think bottlecaps look better with bigger tires anyhow, and they're a lot more practical.
