e38 Style 5s
  • Philo
    Ich esse kleine Kinder
    • 3334
    #31
    As previously mentioned, the back of the wheel needs to be flat with no indentations.
    -tim
    Originally posted by Jordan
    I like the stance
    • Wishno87
      • 6025
      #32
      Originally posted by bmw325csi
      while were on the topic, why hasnt anyone redrilled these yet? Is it possible? they weigh less than the 16's and look way sexier.
      If they are off an E39 they wont work.
      • bmw325csi
        • May 2007
        • 4045
        #33
        dammit
        harry/harout
        • my15thBMW
          • 63
          #34
          Yes style 5's from an e39 can be redrilled. Have a set mounted on a e30 now.
          • Wishno87
            • 6025
            #35
            Pics or it dident happen.
            • BDK
              • Jul 2008
              • 684
              #36
              Originally posted by Van Westervelt
              Use e30 m3 susp, its the only proper way to fit 16" style 5's. :)
              what size tires, do they clear the front calipers?
              • Van Westervelt
                • 9365
                #37
                225/45-16 Falkens. They clear e30 m3 calipers fine, unless you have new pads and rotors, then you just have to remove the anti-rattle spring, or add a 3-5mm spacer.
                • chadthestampede
                  • Jul 2008
                  • 3601
                  #38
                  I just got a quote from a place in PA for $165 per wheel. Seems a bit excessive.
                  Originally posted by LJ851
                  Feedback
                  • einstein57
                    • Jun 2007
                    • 10780
                    #39
                    I refered someone to lax right after I had mine done. He had some e39 weaves and i'd have to assume that they came out similar to jjs since the have a larger hub. Never saw pics though. I do have a spare one that I was going to have completely filled and have the hub 100 per wheel.
                    www.gecoils.com
                    • Mr Two
                      • Jul 2008
                      • 590
                      #40
                      These - why can't they be filled and redrilled?
                      • chadthestampede
                        • Jul 2008
                        • 3601
                        #41
                        Has anyone ever considered the safety of machining the wheel hub down to get a higher offest? I'm not talking a lot, just enough for it to be more viable to run adaptors. Someone educate me as to how unsafe this might be.
                        EDIT: it couldn't be that much more unsafe than those violent redrills. OR COULD IT?
                        Feedback
                        • sefb222
                          • Apr 2007
                          • 1206
                          #42
                          due to hub-bore?
                          hubcentric rings will take care of that.
                          additionally, i'd be WAAAAY more inclined to swap the suspension to M3 5 lug than to redrill those...
                          it's way safer, and is truly the right way to do it.
                          Originally posted by Holland
                          There should be a restraining order to keep kids 100 feet from that car at all times. Plus execution on the sight to anyone who places a shopping cart within 200 feet of the thing.
                          • Wishno87
                            • 6025
                            #43
                            Originally posted by sefb222
                            due to hub-bore?
                            The hub gets too close to the 4X100 drill. Otherwise i would have loved to get those done instead.
                            • einstein57
                              • Jun 2007
                              • 10780
                              #44
                              i think you can basically do a fill and drill for the hub and solve that issue. just hard to find cheap e39 style 5s
                              www.gecoils.com
                              • Jean
                                • 18228
                                #45
                                Hmmmm
