et45
  • bcausey
    • Jan 2010
    • 316
    et45
    What size spacer is typically used for 6j x 14 et 45 - Audi Borbet weaves?
    Thanks, In advance...
  • straight6pwr
    • Sep 2004
    • 3450
    20mm or 25mm would be good.
    • bcausey
      • Jan 2010
      • 316
      et 45
      Thanks : I did a search of the fitment thread -
      Does anyone use the old 14" Audi Borbet weaves or am I the village idiot?
      • straight6pwr
        • Sep 2004
        • 3450
        that offset is so high people tend to stay away.
        • M5wanaB
          • Aug 2007
          • 405
          considering the weaves for our cars are a half inch wider and the correct offset I tend to lean towards the ladder.
          1991 325iC w/ 75k Original Miles, Brillantrot, 5-speed, 16" BBS RX's, Black Leather Sport Heated Seats, LSD, and Diving Boards for life!!!:D
          • bcausey
            • Jan 2010
            • 316
            Hey M5wanaB, mine is an 88 Brillanrot vert, same configuration as yours only with the bottlecaps - just have a set from an old audi and was hoping... probably would look goofy huh? but free is free and the cost of spacers isn't overkill. Give some thoughts...
            • HarryPotter
              • Jan 2010
              • 3642
              Could almost pick up e30 weaves for the cost of spacers.
              John F. Kennedy
              • StereoInstaller1
                GAS
                • 22679
                Save for a set of Ronal 15's
                Closing SOON!
                Thanks for 10 years of fun!
                • 87e30
                  • Jul 2008
                  • 5676
                  It's just one of those situations where it isn't worth it. Sure it could work... but doesn't mean you should do it.
                  To give you an example, a 7 inch wide wheel at et25 is PLENTY conservative. So if you ran a 20mm on a 6inch wide wheel you'd still be sitting very far inside the fender. It's just not worth it.
                  I just hate everyone.
                  No need for discretion.
                  • bcausey
                    • Jan 2010
                    • 316
                    et45
                    Okay, that is just what I needed to know. Thanks for the input.
                    Where can one find those e30 weaves for cheap?
                    • daniel
                      • 6703
                      are they even the correct lug pattern?
                      look in the wheels for sale section if you want e30 weaves.
                      http://instagram.com/dslovn.drives
