Can I run 0 +/- offset?
  • MonkeyMadness
    • 3251
    Found a nice set of XXR 522 Rims! 15x8 or 16x8 +0 4x100
    and would like to know If I can run 0 +/- offset..
    I have H&R sport springs and 15mm Drop-hats..
    I know I'll have to roll my fenders...
    Could I buy these and not have to worry about anything..
  • 5KWattson
    • Apr 2009
    • 809
    i have the 16X8 in black chromium with the zero offset i had to roll/pull my fenders alot!!! to make them not rub
    "God created turbo lag to give V8's a chance" Taylor D.
    • Fcknslo
      • Nov 2009
      • 171
      pics?
      • 5KWattson
        • Apr 2009
        • 809
        • Fcknslo
          • Nov 2009
          • 171
          I was just looking at those wheels and I'm sure they look sexy as hell in person compared to your cell pics. what offset woudl you reccomend then? because I'm not big on wheels but would love to have a good set and not mess them up haha.
          thanks man and thats the final decision i'm getting some 522's lol
          • 5KWattson
            • Apr 2009
            • 809
            yes they do sorry my cam has a dead battery currently, the zero offset is fine if you run the 205/45/16's tire and roll the fenders alot, but if you dont wanna do that much work id go with a +25 offset with the 16X8 and you can run up to a 225 wide tire w/o rubbing
            • skatingzooyork
              • 251
              I thought w/ a 8" wide wheel and a et25 you would hit the strut housing?
              http://www.jfalesphotography.com
              91 318is m50nv - New toy/project
              95 540i - Wife's DD
              • einstein57
                • Jun 2007
                • 10780
                this. you'd probably need at least 2mm spacers.
                www.gecoils.com
                • OOMPH!
                  • 3487
                  It depends on the width of the inner barrell as well.
                  • skatingzooyork
                    • 251
                    Um that doesn't even make sense...
                    The inner barrel effects the mounting surface which then measures against the centerline so the offset is the offset.
                    95 540i - Wife's DD
                    • 5KWattson
                      • Apr 2009
                      • 809
                      Here are some better pics of the wheels, again 16X8 with 0+ offset, 205/40/16 alot of rolling an some pulling of the fenders to get to where they wont rub
                      • OOMPH!
                        • 3487
                        Nice! Wheels are sitting good!
                        I know the offset is the offset, I was referring to 3 piece wheels where you can have different size barrells and interchange them. A 5.5" inner barrerll will give you more clearance from the strut than a 6" inner barrell would it not? Ok.
                        • skatingzooyork
                          • 251
                          Yes you would get more clearance but you would also be changing the offset ;)
                          So no matter what the wheel configuration is, an 8" wide wheel w/ a 25offset will still have the same problem.
                          95 540i - Wife's DD
                          • OOMPH!
                            • 3487
                            The inner barrell doesn't change the offset of the wheel, it changes the width but not the offset. If you change the lips then you start affecting the offset.
                            And yes a 8" wide wheel with 25et will have the same problem :)
                            • DTM190
                              • Nov 2008
                              • 1107
                              As soon as you alter the width, whether it be the inner our outer, you are changing the offset as the centre line will be different
                              Originally posted by der affe
                              first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
                              if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
