Can you Dremel off excess powdercoat?
  • Jand3rson
    • 37587
    When my wheels were powdercoated, they did the WHOLE wheel, including the mounting face and the inside of the centerbore. The mounting face being coated isn't an issue, but the thickness of the coating has made my centerbore just a hair too tight to fit onto the hub center ring of my adapters. Can I use a Dremel to remove the coating just far enough into the centerbore of the wheel to make a clean fit?
  • Philo
    Ich esse kleine Kinder
    • 3334
    How thick is it? I would take a sander to the backside. It is recommended to have a paint free mounting surface.
    And for the centerbore, a dremel should work, just don't get at it too much. Wouldn't want a square where the circle goes.
    G/L
    -tim
    Originally posted by Jordan
    I like the stance
    • brianao34
      • Jun 2010
      • 660
      You can sand off powdercoating by hand, its not that bad. I'd do that before I but a dremel to my wheels
      • george graves
        • 20003
        You can remove it by first smacking your power-coat guy upside the head.
        Originally posted by Matt-B
        • JoeyBones
          • 422
          1. I agree with George
          2. Cheap wheels? ya dremel Nice wheels, elbow grease and sand paper.
          3. Get a bore hone for a drill and use that...
          • george graves
            • 20003
            Power coat is plastic. Acetone eats (some? all?)plastic. Try that?
            • Brian D
              • Mar 2006
              • 832
              I've read of people having lug nuts/bolts loosen because of powdercoating being on the seating surface of the wheel and at the nut. Keep an eye on your torques for a while.
              1973 Bavaria
              • JoeyBones
                • 422
                Only problem I see with using chemicals is possibly going too far with it and ruining the finish elsewhere....I'd stick to something mechanical
                • Jand3rson
                  • 37587
                  You guys know not of my skills with a Dremel, I'm a fucking surgeon. This is the guy that just removed the pinstripes from his car with one.
                  • rhett325i
                    • Jan 2005
                    • 575
                    I've seen them sand excess powdercoat on Orange Couny Choppers. What's good for them has GOT to be good for r3v.
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      Yes, clean it up. I would suggest taking everything off the mating surface. Even a little rust on a hub left when installing new rotors can cause vibration, so this is no different.
                      • Jand3rson
                        • 37587
                        Just got finished with the centerbore of the first wheel, using solely the Dremel, and it worked beautifully, the wheel fits right on now.
                        • george graves
                          • 20003
                          Pic-tars of your ssssk-illz please!
                          • einstein57
                            • Jun 2007
                            • 10780
                            How about a little bit of paint stripper on the hube and face. Use a lot of soap and water to hose it off and you should be golden.
                            www.gecoils.com
                            • Spaz
                              Crazy Canuck
                              • 2276
                              Nice, Like suggested by others i'd suggest inspecting around the bead mounting area of the tire and the lip. Make sure it is smooth and free of bits as it might leak. Along with the hub mounting face should be clean.
                              -Cam
                              Cam .W '91 325is
                              Spaz's 1991 Alpine White???? S52 Build Thread...
