front hub replacement question need help asap
    Can i use a cotter pin on the old nut when i reinstall or do i have to by the new one. And if i carefully remove dust cap can i re use it ??
    Always best to use a new nut and cap.
    If you must, sure, if you don't trash it you could reuse them both. The nut likely won't line up the same when retorqued, you just use a flat screwdriver and a hammer to bend a tab into the slot on the stub axle.
    Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
      If it doesnt line up i cant reuse then ehh??
        No, you just bend the lip in wherever it lines up. What I was saying is don't just tighten it until it lines up, actually torque it to spec.
          And the axle nut is 36mm??
            Pretty sure it's 32mm, unless it's an ix, then they are 36mm.
              the one on bav autp said 36 mm
                I have a 36mm socket, and it won fit inside the hole. But im sure its a 36 mm... is there a certain socket i need
                  Just confirmed on my spare parts. Front is 36mm and rears are 30mm.
                  I just have a 36mm Impact socket and it fits fine. You're using a deep well socket, correct?
