negative camber tires...
  • e30slidewayz
    • 813
    I've been meaning to post this for a couple days. Optima Sports has developed a camber tire that allow for negative camber with the entirity of the tread remaining in contact with the road at all times. I've drawn a picture of what it looks like (to avoid copyright law bs). Check out my dope MSpaint skills yo. The inner sidewall is shorter than the outer sidewall allowing the tire to tip inward. Better cornering, even wear, dope stance... I'm definately getting a set if they aren't crazy expensive when they come out. ETA: 2 years. What do you guys think?
  • Holland
    • Nov 2008
    • 7204
    Something tells me that's not safe...
    Originally posted by DEV0 E30
    • xwill112x
      • Jan 2009
      • 4236
      wtf, the neg camber wear on an e30 tire isnt even that bad. just rotate them. besides, who even expects to get long life on a tire for a e30? if it lasts more than 4-5 months, its good.
      • 5KWattson
        • Apr 2009
        • 809
        sounds like you are smoking some sort of plant that just grows in the ground but if you just happen to set it on fire /\/\ this is the affects
        "God created turbo lag to give V8's a chance" Taylor D.
        • Holland
          • Nov 2008
          • 7204
          If the outside of the tire is taller than the inside, it shouldn't even be able to roll straight, which would wear faster than a regular tire. Makes no sense.
          • DTM190
            • Nov 2008
            • 1107
            That picture looks like my rears tyres lol
            Originally posted by der affe
            first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
            if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
            • E30Idea
              • Mar 2007
              • 2196
              This is because this entire thread is BS.
              ** Lot's of M20 turbo parts for sale.**
              Turn key track car.
              http://www.r3vlimited.com/board/showthread.php?t=222066
              • F34R
                sLaughter
                • 12376
                Wow...I was talking about this with my friend today. Weird as fuck, I did not even know they had this planned. I was just thinking it because of my current camber wearing.
                I'll take camber wear than that design.
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                • daniel
                  • 6703
                  http://www.autoblog.com/2010/08/13/v...ires-inventor/
                  http://instagram.com/dslovn.drives
                  • 325ix
                    • Aug 2009
                    • 7783
                    the simple solution is to run properly sized wheels and tires.
                    • DTM190
                      • Nov 2008
                      • 1107
                      I would give them a go, my first concern was that a taller sidewall on the outside would mean more flex on the outer sidewall but it seems they have that covered.
                      Interesting and like anything new there will be love/hate
                      • BoxDriver86
                        • Jul 2009
                        • 912
                        Or a decent alignment. I have tons of camber and no strange wear issues.
                        • ak-
                          • 12422
                          My guess is that they are going to be so expensive that it isn't even fucking worth it.
                          1991 325iS turbo
                          • 325ix
                            • Aug 2009
                            • 7783
                            At least that but, I think it is dumb to run wheels so wide you have to run tons of negative camber to fit them.
                            • Ray Smoodiver
                              • Jun 2004
                              • 8809
                              How is this different to TRX?
