Will this fit under my e30?!?!?!?!?!?!?
  • ipunchfish
    • Oct 2009
    • 106
    205/40/17 with wheels at an offset of +35. My car is dropped a bit. I wanna make sure these will fit.
    Thanks! :D
  • Wishno87
    • 6025
    What size are the wheels?
    • Vince30
      • 2318
      ^ I'm hoping 17s since that is what the tires are.
      • Wishno87
        • 6025
        Well the width of the wheel can be a factor too.
        • Vince30
          • 2318
          Ok sorry for being a smart ass.
          • bmw325csi
            • May 2007
            • 4045
            seems like they would fit regardless of width. I used to run 215/45r17 with the same offset, needs spacers to look proper though!
            harry/harout
            • Van Westervelt
              • 9365
              Wheel width can come into play, but typically for just tire fitment you only need the offset and tire specs as given. This is all assuming you know the wheels do fit since that wasn't included in the OP.
              • ipunchfish
                • Oct 2009
                • 106
                Wheels are 17 inch. Why would it be anything else? Is that for tire stretching? (lame)
                So I guess the wheels will fit? Maybe? Eh?
                • Wishno87
                  • 6025
                  Ya they most likely will.
                    • 37834
                    He asked the WIDTH of the wheel. If it's an 8+ inch wide wheel, it could change things.
                    Grover Beach, California
                    BimmerHeads.com
                    • Jand3rson
                      • 37587
                      • RAYREY
                        • 212
                        with a 35 offset chances are you'll need spacers (15 mm) Good luck...
                        1991 325i coupe
                        1992 318i conv
                        2002 540i sedan
                        What did the e30 owner say to the other e30 owner? LOOKING GOOD!
                        • ipunchfish
                          • Oct 2009
                          • 106
                          Winner! Technically the wheels on my car right now have a +30 offset so we will see how they fit. It seems like they will not clear the suspension.
                          More on this later. Anyone want to let go of some spacers? :D
                          • 8380 Labs
                            • Oct 2006
                            • 2990
                            offset doesn't mean a thing without knowing the width of the wheel.
                            8380 Laboratories
                            M3 Champs Poster
                            • 2002maniac
                              • 4260
                              OMG! We still don't know the width??!!??!??
                              If they are 17x7 they'll fit fine. 17x7.5 might need a 10mm spacer, 17x8 would need a 15mm spacer.
                              like ledjetta said, offset is meaningless without width specs.
