Fill & Redrill, is it safe?
  • Coyote_ar
    • Sep 2009
    • 175
    Well, just that, it's safe?
    ---E30 320i Hennarot 1984 Sedan---
  • dreamchasin
    • 3890
    Yes it's just as safe as a regular wheel with no fill and drill.
    90 325is alpine2 m50b25 becoming a dorifto car.
    • 8380 Labs
      • Oct 2006
      • 2990
      that's not entirely true. it depends on the original pattern and the new pattern being drilled. the hub bore, how much material there is on the back of the wheel, etc.
      there are a ton of factors involved which make some wheels better than others, and some that you just can't safely do.
      8380 Laboratories
      M3 Champs Poster
      • Stephen
        Шлем ишака
        • 10774
        Yea, and while a properly fill and drilled wheel should be more than safe enough for average use, i dont think you can say its exactly the same. Like led said, not all wheels can be done either, and some wheels are stronger (forged or cast) than others.
        OP, any particular wheel you are considering?
        • jasonsnoddy
          • 1900
          is it secret?
          Originally posted by stewie30luvr
          ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
          Originally posted by JakeP
          with a coathanger
          • Coyote_ar
            • Sep 2009
            • 175
            i had in mind the e36 m3 style 44s. So it would be a 4x100 drill onto a 5x120 pattern. AFAIK those are cast wheels.
            Thanks for the imput.
            • dreamchasin
              • 3890
              i have 5x120 style 19s that are fill and drilled to 4x100. i havent driven them yet but i will let you know when i finally get tires.
              • bad_azz_bmr
                • Sep 2004
                • 433
                fill and drill doesn't work with an open lug wheel, you will need something with a full centre cap to hide the fill and drill.
                • Stephen
                  Шлем ишака
                  • 10774
                  I think you could clear adapters with those though. Arent they fairly high offset?
                  • Coyote_ar
                    • Sep 2009
                    • 175
                    thx
                    no good just to fill, drill, and then some paint to cover any difference on the fill??
                    yeah, ET47. but i dont know how safe those adapters are.
                    would you say the adapters are safer than fill&drill?
                    • Stephen
                      Шлем ишака
                      • 10774
                      i cant say for sure, but adapters are safe, and you can use it with that wheel. you cant really fill and drill that wheel so thers not really a comparsion.
                      fwiw, i would run adapters or fill n drills, and know many who have either or.
                      I'm currently running adapters, 2 weeks ago just did an 1100 mile roadtrip on them too.
                      • Holland
                        • Nov 2008
                        • 7176
                        They wouldn't fit without an adapter or spacer, ET 47 would be rubbing on the strut tower. ET20 - 25 is the norm on our cars.
                        Originally posted by DEV0 E30
                        • Wishno87
                          • 6025
                          In your specific case you would be much better off getting some adapters with such high offset wheels.
