Prelude wheels with 5 lug adapters?
  • Javier h
    • Sep 2007
    • 1189
    Always wondered about this. 5 x 114.3
    Edit: Ignore, offset is like 40
  • Danny
    • 14216
    Yeah but adapters would push that offset to like 20. It can be done.
    • Stephen
      Шлем ишака
      • 10774
      Yea, you need higher offset wheels to run adapters
      • RickSloan
        • 2401
        i just had the perfect set of adapters for sale for this...
        Need Illustration or Design work? www.robbiebyerly.com
        • 325ix
          • Aug 2009
          • 7783
          Those look similar to Porsche twists.
          • Javier h
            • Sep 2007
            • 1189
            Interesting. 17 inch Porsche twist reps are 5 x 100.
            There's a load of those 16inch prelude wheels everywhere. If you every hit a rim, they would be fairly inexpensive to replace.
            This adapter should work, right?
            http://cgi.ebay.com/ebaymotors/4-LUG...Q5fAccessories
            • trackjunkie21
              • Jan 2010
              • 3962
              Those actually wouldn't look to bad, Like a mix of porsche twists and bmw throwing stars.
              Originally posted by Wh33lhop
              VANOS: sometimes you just need to go full retard.
              • Pabl0
                • Jan 2009
                • 47
                Originally posted by Javier h
                those adapters are 44mm thick creating a jacked up offset. not to mention they're 2 piece and would weigh a ton and they have no hubcentric lip. i can make you a one piece adapter and hub centric if you end up needing them. wheels do look pretty good as well
                • Holland
                  • Nov 2008
                  • 7212
                  Those have potential.
                  Originally posted by DEV0 E30
                  • worangejuice
                    • 1837
                    Those are gross. Stock Prelude's are STOCK.
                    Use the adapter to go to Porsche or Merc wheels.
                    Or BBS's seem to run cheap when they're 5x114.3 and high offset. do this.
                    www.woranges.tumblr.com
