Caps
Capless or capped?
yes, he sold me these and after i sent the paypal he said that they were 4x108 and would need to be redrilled. Just this wheel that is pictured is filled and drilled, the rest are just "multi lug" redrilled to 4x100.
It probably would look less retarded with the caps on when all the wheels are actually bolted to the hub. I need 5mm spacers to clear the front calipers, and ill probably run 10mm in the rear.
`92 325 vert - `90 325 coupe `99 m3 - Instagram @e30LComment
i can see it looking nice, maybe you can black out the center so when you decide to not run caps, in my opinion the caps are big and completely flat and look awkwardyes, he sold me these and after i sent the paypal he said that they were 4x108 and would need to be redrilled. Just this wheel that is pictured is filled and drilled, the rest are just "multi lug" redrilled to 4x100.
It probably would look less retarded with the caps on when all the wheels are actually bolted to the hub. I need 5mm spacers to clear the front calipers, and ill probably run 10mm in the rear.]Comment
Updated the OP with these pshops
Another idea i was toying around with was putting a hex cap on the centercap (obviously without the BBS emblem, i would use a BMW Roundel) and use a grayish/black paint for the remaining polished area of the centercap
ya without caps looks bad on this wheel, but the caps look off...-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good lookingComment
