Your thoughts on my front wheel offset/fitment
  • kalib0y
    • Dec 2004
    • 3620
    Guys,
    I have e30 m3 suspension and am running 17x8.5 +13 Rondells on 235/40/17. I dont have any camber plates and are on H&R sport springs. I would like to get coilovers or a higher rate (lower stance) spring like IE stage 3s in the near future.
    What do you guys think of my front fitment? too aggressive?
    95 7.1L 16V E36 M3
    Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
    LIKE my Facebook Page! CLICK HERE
  • CHIF8008
    • 3447
    your front seems to poke more than the back does
    -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
    -The Beauty in the Tragedy-
    MECHANIC SMASH!!- (you all know you do it)
    Got Drop?? ;-)
    But of course
    E30s are know to be notoriously really really really ridiculously good looking
    • kalib0y
      • Dec 2004
      • 3620
      They are the same offset front and rear 17x8.5 +13, no spacers...etc
      95 7.1L 16V E36 M3
      • Lof8
        • Oct 2006
        • 2827
        The issue of fronts poking more than rears is very common. I've seen it on a number of auto manufacturers. It becomes an aesthetic problem when dealing with aggressive fitments because you can see the relation to the fender line more easily.
        In your case, some camber up front will help bring them in line. Spacers in the rear would help as well, but you may not have room for them on those late model arches.
        I used a staggered setup to avoid the front-only-poke that I can't stand.
        S50'd
        Originally posted by TDE30
        What is this faggy shit I have happened upon?
        I can always live in a M3. Can't M3 a house.
        • kalib0y
          • Dec 2004
          • 3620
          It seems like I would need alot of camber to make the fronts fit aesthicly (spelling) my other option is to run different wheels like a 17x8 +20
          95 7.1L 16V E36 M3
          • Lof8
            • Oct 2006
            • 2827
            I agree and a narrower wheel is probably the route I'd go too.
            S50'd
            • 2002maniac
              • 4260
              Roll the fenders like mad and run 3 degrees of negative camber and you may not have any issues, but that's pretty aggressive. You could run the same size tire on a 17x8 et20. It would fit much better and traction wouldnt suffer much.
              • idanity
                • Jun 2006
                • 775
                i have some 17x8.5 's +25 offset
                i don't have tires yet, but will be buying some 245/35's too. (you got falken 452s? )
                and i can photo what they would be like fitted, in a week or so..(depends on when i get the tires) (btw, im also running g.c. and ie camber plates)
                3 pedal club
                200,k+ club
                cabrio club
                port-matched- polished- purring www.BMWpark.org
                </div>
                linux since 1999
                • mizhan
                  • Dec 2010
                  • 26
                  yup, front pokes a bit too much for my taste.
                  • HarryPotter
                    • Jan 2010
                    • 3642
                    That would be so sexy, just get some spacers for the rears and roll the rear fenders cleanly.
                    I love the aggressive look of a wider stance, you can go too wide however. But yours is looking pretty damn perfect.
                    John F. Kennedy
                    • richardkeith97
                      • 1693
                      get gc camber plates for the front. You can play with ur camber and it will lower your car another half inch. Then get a spacer for the rear wheels and some thicker spring pads or just stack a couple. Should be perfect.
                      • kalib0y
                        • Dec 2004
                        • 3620
                        Switched over to some style 5s
                        Now I'm going to focus on coilovers and sways.
                        These Rondell 58s will be for sale soon
                        95 7.1L 16V E36 M3
