So im looking on Tire rack and i see some OZ wheels I like
Offset: 37mm Backspacing: 5.47" Bolt Pattern: 4-100
Rec. Tire Size:205/50-16
Weight: 21.2lbs.
The same wheel but for a Volkswagen Rabbit is $30 cheaper.
Now for the Question if I go down a size the off set is different by 1 how much would that effect me would i need a spacer or would i still be good to go?
Does anyone know hoe far you can go without using a spacer ?
Weight: 21.2lbs.
