Offset question
    Offset question
    Hey, i just got a set of 16"wheels with a 40mm offset. I'm pretty positive that I wont run into any issues here, but its a 16x7 and i'm going to be running 225/45s, I think a 15mm spacer should be perfect, but I'd like a 2nd oppinion before i make spacers.
    -Addis
    Doing something M50 related? -> http://www.addissimo.com
    On Myspace? ->http://groups.myspace.com/r3vlimited
    BF2142 SN = BillyGoose
    From what i hear as long as you are in the 20's in offset, you should be good. You may also need longer studs.
    THis doenst include ix's.
    www.ThundaCats.com
      A 15mm spacer will be perfect for you. You'll also need longer lug bolts or a stud kit with long enough studs.
      Also, 225/45 is a bit wide for a 16x7, but it will work. However I think you'll be happier with a 205/50R16
      332iS R.I.P.
        The tire specs say that it'll fit, otherwise i probably wouldn't go that route.
        Why do you think I'd be happier with 205s?
        Thanks-
        Addis
          Thanks-
          Addis
          Strictly appearance wise. Yes the 225 fits the 7inch rim, but it will just look a little "bubblier", plus there is a much larger tire selection in 205/50R16. Both will work, if you want the extra width, I say go for it.
          332iS R.I.P.
            awesome... I was a bit worried for a second. I dont care all that much how they look- i'm just after the contact patch- I'm finally outdriving my tires with the m50 swap :) Thanks for your help.
            -Addis
