? about fitment
  • bpmack16
    • 1521
    ? about fitment
    I want to get a set of keskin kt1's but the only set i can find 16x9 et 20 will thease fit on all four corners??? what about et30 same size???
  • 2002maniac
    • 4260
    nope, you'll need 10-12mm spacers to fit the et20 wheels. THe wheels in your sig are awesome though, why change?
    • bpmack16
      • 1521
      they are for my other car. Will the et 20 rims with 10-15mm spacers poke way out or sit flush??? I know nothing of rims or tires.:(
      • bpmack16
        • 1521
        so if i had an rim that was et20 and added a 10mm spacer would that make it et30 ????
        • Axxe
          • Aug 2004
          • 3355
          It would make it ET10, and it would poke.
          Keep it slideways!!
          • 2002maniac
            • 4260
            Poke in front, flush in the back. They ARE 9" wide. The fronts would rub on the strut without spacers.
            • bpmack16
              • 1521
              so should I do 16x9 rear 16x7.5 front all et 20 ????
              • bpmack16
                • 1521
                I don't want to poke i want to be flush. If any of you know where to get a set of keskin kt1" that will work on my car post size and where to get them. Thanks for all your help.
                • bpmack16
                  • 1521
                  would a 16x7.5 et20 rub or poke out up front and what about 16x9 et15 rear will they rub.
                  • sarcasmkillsme
                    • Oct 2007
                    • 255
                    Alloy Wheel & tyre fitment calculator - it calculates inset, poke, speedo error, tyre stretch and loads more.
                    Use that site. Put in your current wheel specs and the new wheel specs to see the difference.
