Multiple Spacers??
  • racerjay88
    • 88
    Multiple Spacers??
    I need seasoned pro's advice.
    I did some research on getting the used 15 x 7 325ix wheels to fit my 325e sedan and I am sure I need a 10mm spacer to get the wheel to fit (Tire size is 195/55). Is it safe to double up spacers? Say like put a 3mm spacers in front of a 10mm? I am going with Velocity's 10mm kit with the longer wheel bolts, Could I squeeze another 3mm spacer in between the 10mm spacers and the hub face without and issues?
  • AndrewBird
    The Mad Scientist
    • 11898
    As long as they are hubcentric spacers, it shouldn't be a problem. I just wouldn't stack two larger spacers (like two 20mm). You might even consider using a dab of silicone to help hold them together to help when putting the wheel on. If you aren't using studs and just using bolts, they are going to be a paint to line everything up. Only a tiny bit though. You don't want to make the spacer not sit flat.
