new ESM's i need elp
  • korea619
    • Aug 2009
    • 39
    so i got esm 002
    16x 7.5 et 20
    for fronts and i seen the website
    im getting 16x9 in the rear but the come in et20 and et10 i reallly want that staggered look so wgich willl actually look deeper the wheel already says it going to have a 3 inch lip but idk if offset will affect it
    your help would be great
    M20B25 leave me on the straights ill take you on the turns
  • bmw325csi
    • May 2007
    • 4045
    Et10 is made for the front so you would need rolling/pulling of the fenders. Mine is et20 in the rear and the fitment is perfect. Check sig.
    harry/harout
    • Gadea
      • 454
      I´m not sure what do you need elp with. I´m guessing you may need to roll your rear fenders if going that route.
      1998 528i auto on staggered DSII
      • bmw325csi
        • May 2007
        • 4045
        et20 all around but front have a 15mm spacer
        harry/harout
        • korea619
          • Aug 2009
          • 39
          ok cool that all i needed i wasnt really sure how that worked so et 20 all around
          plus i do plan on getting fender flares so i should be good
          thanks guys
          • Ant_e30
            • 292
            ^ why get et20 all round when you know you need to run a spacer? i prefer wheels that fit straight up without a spacer... i'd say go ET10 all round. or, do ET10 front with some camber (via the use of camber plates) and get them to tuck in a bit more, and run ET10 rear and let them sit more straight up, which they will as camber doesnt go as crazy up back
