16x7 -0 offset with a 205/50 Tyre?
  • MonkeyMadness
    • 3251
    WIll this work at all...?
    I have the rims and tire's already
    I rolled my wheel wells but haven't pulled them...
    Can I get away with this setup or do i need to have them pulled too?
    thx
  • UDelaware30
    • Dec 2009
    • 336
    mount 'em up and find out...
    • MonkeyMadness
      • 3251
      If only i could...ugh They're 5lug and i'm still 4lug, i ordered adaptec adaptors from 8380 fab a week ago. I would like to get the needed info before mounting. if someone is running a simular setup with out issue, or if i do have to pull the fenders i can do it now before i chew up new rubber...
      • Wh33lhop
        • 11705
        205/50 is pushing it--it may work depending on your ride height. I'm assuming they will be ET0 AFTER the adapters.
        paint sucks
        • E30SPDFRK
          • 5716
          As long as that offset is after adaptors it'll work fine.
          Byron
          Leichtbau
          • MonkeyMadness
            • 3251
            Yes et0 after the adaptor on the front.. and -5 on the rear.. and yes i gotz sum low.. :down: :-D
            • Philo
              Ich esse kleine Kinder
              • 3334
              What suspension are you on?
              -tim
              Originally posted by Jordan
              I like the stance
              • MonkeyMadness
                • 3251
                stock with Eibach cup 1.5 and drophats, stock strut inserts in front, and bilys out back.
                • Wh33lhop
                  • 11705
                  I would get some stiffer suspension if I were you. Eibachs with stock struts is not going to be very resistant to compression and you will probably get a lot of rubbing.
                  paint sucks
                  • einstein57
                    • Jun 2007
                    • 10780
                    NITTO NEO GENS are wider then alot of other tires
                    16x7 et 20 maxxim remembers. So first thing i had to do was grind down some spare bolts i had laying around so they would be flush with the spacer. if your car has eccentric trailing arm bolts and you are running the correct alignment these are way to thick. If your car is dropped and has the normal xtreme camber our car exhibit then these are perfect.
                    proper camber side
                    non corrected camber side
                    www.gecoils.com
                    • MonkeyMadness
                      • 3251
                      Originally posted by einstein57
                      IDK about you, But I was always taught to hide the bodys in the trash can not next to it...
                      Your doing it wrong..
                      • Ant_e30
                        • 292
                        ^ lol good call.
                        BTW whenever i'm fitting rims and things are tight so to speak, i jack my car up and whack it on stands, then jack the wheel up independantly with my jack and watch it move up and down. You can obviously also turn your wheels and do the same thing. This then shows you the complete travel and shows you if/where you hit
                        • Philo
                          • 3334
                          /\ At first I thought it was a spam post, then soon realized it was just a very poor use of the english language.
                          Also, You're going to have trouble fitting that tire size.
                          -tim
                          I like the stance
                          • Pussy30
                            • Feb 2011
                            • 463
                            I ran 15x8 and 15x7 0offset with 205 50 and 195 50 fit and lookes awesome but rolling rear fenders is a must
                            • MonkeyMadness
                              • 3251
                              Ya i rolled the fenders but worried I will have to go back and pullem
