What wheel spec needed to run WIDE tires
  • Jean
    • 18228
    To run something like 275/35/15 what wheel spec should I be looking for?
    Width/backspacing/offset?
    Thanks
  • 8380 Labs
    • Oct 2006
    • 2990
    that's gonna be pretty tough without some fender work.
    9" - 9.5" wide.
    hard roll on the fenders.
    offset somewhere around et25, but i think you'd still have some clearance issues.
    this would be for the rear, no hope for that up front on anything resembling stock body panels.
    8380 Laboratories
    M3 Champs Poster
    • Jean
      • 18228
      Yeah, fenders will have to be cut/boxed that's fine. I am more concerned with clearing the INNER area.
      • 8380 Labs
        • Oct 2006
        • 2990
        9.5 in the rear will clear with et20 for sure.
        8380 Laboratories
        M3 Champs Poster
        • z31maniac
          • 17566
          In the front you have to be in the ET0 range so the tire will clear the strut, IIRC. On a 15x9 that is.
          www.gutenparts.com
          • nrubenstein
            • 3148
            If you're going to cut up the fender, go big. 10-11" wide is the trick.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • Jean
              • 18228
              Any off the shelf wheels you can suggest in the correct config?
