Positive camber tire wear
  • foundation982
    • Apr 2011
    • 180
    Yes I'm a e30 "noob" and my car is slammed pretty low. I started noticing tire wear on the inside. After some brief researching I found camber plates but noticed that they're for the front wheels. My front aren't that bad it's the rear that are really positive.
    What are some ways around this? (besides lifting my car)
  • LJ851
    • 7919
    If your car is low you have negative camber (tires in at the top). You can buy weld on adjusters for your rear subframe to correct your excessive camber and toe. The toe is what is wearing your tires BTW.
    Lorin
    The M30 is God's engine.
    • foundation982
      • Apr 2011
      • 180
      Well now I feel like a dumbass calling it positive. Thanks for the input though. I know toe wears them quick, but wouldn't having negative camber contribute to this?
      • LJ851
        • 7919
        A lot less than you would think. The parts to fix your situation are fairly inexpensive , can you weld?
        Lorin
        • foundation982
          • Apr 2011
          • 180
          sadly, no. But my dad is an excellent welder and I still live with my parents!
          • Eric
            • 5142
            this is what you need:
            http://www.akgmotorsport.com/catalog...ion%2FBushings
            part number RTTC30F
            • Adrian_Visser
              • Jun 2006
              • 2823
              You can also buy raised subframe bushings that will correct for some of the camber and toe problem, adjusters are better though.
              '89 Alpine S52 with goodies
